Bilstein 5100 Info - From Bilstein
Hey all
I emailed Bilstein about their 5100's and why some have 2 settings and some have 3. I also asked them to settle the dispute on which way the rears get mounted. Boot up or boot down.. Here is their reply..
----- Thanks for you inquiry for Bilstein shock absorbers. You have made a wise choice with your decision to use Bilstein 5100 Series to level your F150. I am sure you will be very pleased with the end result.
As for your questions. First, Bilstein produces two different shocks for this application. One of which, is proprietary through RCD Suspension. The other is Bilstein's general aftermarket offering. Both shocks are exactly the same with the exception of the snap ring grooves.
Part# BE5-C298-H1 is Bilstein's standard product. This shock has 3 grooves for 0" - 1" - 2" ride height options.
Part# BE5-C293-T0 is the RCD product. This shock has 2 grooves, 0" & 2".
As for the rear mounting orientation. The rear is designed to mount body up with the boot down.
Soooooooo, with that being said, has any body used the 1" setting?
i believe Bilstein (rear) was designed to be mounted where you can read the label properly (not upside down). ive googled bilstein 5100 enough to notice that some has boots down with the wording positioned right while the one i have on mine has boots up but with the wording positioned properly as well.
Also, then, is the 1" you ask about a 1 inch drop? Is this saying the C298 is for lowering and the C293 is for lifting?
0" means stock height, that's all.
Part# BE5-C298-H1 can be set for stock height, +1", or +2".
Part# BE5-C293-T0 can be set for stock height or +2".
Don't let the dashes in his text fool you into thinking they mean minus, he's just separating the numbers
Thanks, Xterrable, for emailing Bilstein about this and posting it up here.
A 2WD takes the BE5 C300 HD and BE5 C301 HD
Part# BE5-C300-HD can be set for stock height, or +2".
Part# BE5-C301-HD can be set for stock height or +1".
So then is it true, that in the front a 2WD Bilstein set at the +2 height would be the same as a 4WD Bilstein set at the stock height?
And in the back you can only use the FX2 one inch block on the +1 setting with the C301-HD because they are too short for the 2" block?
At the risk of beating this to death, I'm still not sure. In this example, stock is is for a 4WD, which has a two inch block in the back. I thought the front is also higher than a 2WD.
If you're truck is otherwise stock, just get the part number that Bilstein lists, it will work. If you have a larger block or an add-a-leaf or something else to make it higher, you might want to get a longer shock.
I don't know how much height difference there is between 4x2 and 4x4. But a 2wd with +2" in front is probably close to a factory 4x4.
If you install a taller block or something to make the rear end the height of a 4x4, I would get the 4x4 length rear shock.
Does that answer your questions?
stock 4wd is 2" higher in both front and rear than a 2wd. i believe front is higher due to longer shock and rear is higher due to 2" block (which also requires longer shock).
with that in mind, if you set the front 2wd version of the 5100 to 2", then it will be at height of stock 4wd. with the rear 5100, like previous poster stated, you cant really accomplish, but rather accomodate up to 1" max of lift. using the fx2 1" block will indeed provide you an inch of lift which the rear 5100 can handle.
