Go Back   F150online Forums > Powertrain & Mechanical > Suspension
Sign in using an external account
Register Forgot Password?
Register Photos Vin Decoder FAQ Members Search Today's Posts Mark Forums Read VendorsGarage
Suspension SPONSORED BY:
Thread Tools Search this Thread Display Modes
Old 11-13-2008, 05:39 AM
1997 Ford F-150
Vehicle: 1997 5.4L F150 4x4
RE-torque my body lift bolts ???
When I installed my 3" PA body lift, I remember the instructions saying that I have to go back in and re-tighten all of the bolts to the correct torque specifications after so many miles. It also instructed me to use locktight when initially putting it all on. My question is, if I go back in and re-torque all the hardware then won't that break loose the locktight? Or do I just take the bolts completely out, put new locktight on them, and THEN retorque them down? Or will it defeat the purpose if I remove them first or something?
THANKS!
Old 11-13-2008, 07:13 AM
Garage is empty, add now
Vehicle: 2002 Ford F150
I just finished with my own 3" body lift and was wondering about the re-torques myself. I don't think we need to take them out completely, but that the re-torque is simply to see if any of them have worked loose. I plan on just simply putting the torque wrench on an re-torque.
The signature pic below is without the 3' body, so I need to update. I am also going to post a few pics of the process ASAP.
2005 Lariat Super Crew 5.4L 4x4 Roll Tide!
Old 11-13-2008, 09:10 AM
Vehicle: 2003 Ford F-150 5.4L 4x4
hi, i have a body lifted 03, put on the kit about six months ago, and never bothered to retorque the bolts. i also have offroaded pretty heavily several times since then, and none of the bolts have come loose. honestly, if you are not feeling any play/vibration at any of the mounts, i would not worry about it. the loctite is holding them down fine.
retorquing the bolts is a bigger deal with a suspension lift than a body lift.
Old 11-13-2008, 07:23 PM
It is probably one of those deals where the company says to do it just in case one was missed and more likely CYA.
Old 11-13-2008, 08:36 PM
Vehicle: 2003 Ford 150 4x4
I've had my BL for about 2 years and and I only retorqued my bed bolts and that was because I off roaded it very rough once. I dented my front skid plate and everything... I noticed that a couple of the bed bolts shifted a little and creased the bed liner around them. I had to cut the liner off around the bolts initially to get the OEM ones out because they were covered.
If you installed them correctly and put locktight on them, I wouldn't worry about retorquing them, unless you notice an similar situation to mine. And then, it was only the bed bolts.
There's is no way I'm pulling the seats out, trim, rolling back carpet, etc... just to do the cab bolts. What a PITA. Not worth it IMO...
Never really had a problem though with the BL...
JK007
2003 SCREW, FX4 Lariat
35s on 16s / 3" PA Body Lift / Bilstein shocks /
K&N FIPK / EDGE / Magnaflow True Duals / Other appearance mods
Old 11-14-2008, 02:50 PM
1997 Ford F-150
Yeah but if it needs to be done then I would rather just bite the bullet and do it to be safe. The thing is my truck is squeaking a lot so I'm wondering if they have something to do with it or not...
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company
Emails & Contact Details
Search Engine Friendly URLs by vBSEO 3.5.2
