11-02-2008, 02:39 AM
Garage is empty, add now
Vehicle: 1997 ford f 150
lifting for begginer
im a begginer at this all and am looking for some tips on how i can lift my truck myself
i have a 97 reg cab flareside with 245/75/r16's 4x4
11-02-2008, 06:33 AM
Vehicle: 2007 Ford F150
Get a lift installed in your garage. Then a bunch of tools.
11-02-2008, 08:54 AM
a 3" body lift will be an easy enough task for you and a buddy to take on.
this will allow you to fit 315/75/16 or a 35x12.5
let me know if you have any questions
11-02-2008, 09:57 AM
Just depends on how tall you want to go. A 3 inch Performance Accessories body lift will allow you to fit 35x12.50's on a 10 inch wide wheel, but barely. A 6 inch Fabtech suspension lift will give you more room but cost more. It up to you on how tall you want to go and how much money you want to spend. The taller and bigger tire you go with, the more it cost.
2005 Expy, 305/45-22 Falkens on 22x9.5 Eagle 026s.
2011 Jeep Wrangler Unlimited, 2" lift, 33" BFG AT KO's on 17x9 Eagle 197s.
2012 Ram 2500 crewcab diesel. 5" RCX lift, 355/60-20 Nitto Terra Grapplers on 20x9 KMC XD Spys.
11-02-2008, 10:36 AM
2001 Ford F-150
Vehicle: 2001 Ford F150
Yeah both the suspension and body lift are relatively easy to do yourself with some friends, beer, and tools. Just read through the directions and you'll be fine.
11-02-2008, 09:10 PM
If you've got beers, then you've got friends. Make sure that you have the right tools. And make sure that those beer drinking friends know what they're doing with those tools.
11-03-2008, 04:19 AM
1997 Ford F-150
Vehicle: 1997 Ford F150
Quote:
... are you serious or did i read that wrong? you want the guy to have a lift installed before buying tools to do the job? thats the most retarded thing ive ever read if you meant that!
what happen to jacking the truck up, throwing blocks under the frame and tearing at it like a mad man? hell i did that with a wrecked ranger outside in the soft dirt, had it teetering tied to a tree and my f150 while i ripped the front end apart and tried to repair the buckled frame rail. that part didnt work so well when the hilift jack broke the chain and hit my jaw on its way out.
11-03-2008, 05:54 AM
Quote:
......sure
Everyone should have a lift installed in their house. I've got one. Don't you?
Oh, I don't know.....the truck could fall on you......
But I guess you just answered your own question. A hi-lift jack could break a chain, and hit you on the jaw on it's way out.
11-03-2008, 01:08 PM
1997 Ford F-150
no actually, i dont have one. i do want one but first i have to build my own shop here, since i just moved out and bought my own place that i could build on.
oh and so your not confused, the hi lift jack hitting me has nothing to do with a normal lift procedure, im pretty sure nobody will be trying to lift a wrecked truck with frame damage.
i really dont see how a truck on 4 jackstands (or blocks) will fall unless your getting rough.
11-03-2008, 08:45 PM
Thanks alot guys i think im gunna go with the 3 inch body lift and 315/75/r16's
do you notice any power loss on a 4.6 with that big of tire?
would it be a bad idea to put a 2 inch levelling kit in at the same time?
11-03-2008, 09:12 PM
There wont be HORRIBLE power loss but you will notice alittle.
And you dont need to buy anything to level the truck just crank up your T-bars. its easy and free. (besides paying for the alignment afterwards which you will need if you mess with the Torsion bars)
11-03-2008, 10:53 PM
I agree. Stay away from the "leveling kits" for the 97-03 4x4's. They have to be the biggest rip off ever. Why pay $150 for something that you can do for free?
11-05-2008, 09:11 AM
2004 Ford F-150
Vehicle: 2004 Ford F150
im new as well... will cranking the factory torsion bars change ride quality and make parts go out faster? I really want to lift my truck and get a little bigger tire on there. thanks guys
11-05-2008, 09:18 AM
Vehicle: 2003 Ford 150 4x4
Quote:
Yes, your ride will be a little stiffer and your front end parts will wear faster. But nothing extreme at all in both cases. I've had mine cranked for 2 years with no issues.
JK007
2003 SCREW, FX4 Lariat
35s on 16s / 3" PA Body Lift / Bilstein shocks /
K&N FIPK / EDGE / Magnaflow True Duals / Other appearance mods
11-05-2008, 12:33 PM
2004 Ford F-150
Thanks man, also, i was wondering if i could fit 33s by just cranking the factory torsion bars. I dont take it offroad that much... but, i may want to sometime, not anything extreme though, just a little bit of mud maybe. Any ideas? i want it to look good but be efficient too.
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is On
