F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Suspension
Thread Tools Display Modes
Old 10-15-2008, 10:24 PM
Vehicle: 1999 Ford F 150
97 silverado keys in a 99 f 150??
First questuion is will the torsion bar keys from a 97 chevy silverado 1500 fit in my 99 f 150, both 4x4. And my second question is it going reasonably drop me lower? And bring the chev higher? (worth the swap?) Thanks guys
Old 10-15-2008, 10:46 PM
Vehicle: 1999 Ford F150
Ummm ive heard of people swapping the Torsion Bar Adjustment keys from Chevys into Fords but not sure the point.
Maybe they are indexed better to get more lift? Not really goodfor the suspension.
"Project 1ton150" build thread coming soon keep an eye open
http://www.f150online.com/forums/sus...ere-we-go.html
Old 10-15-2008, 11:11 PM
Vehicle: 2005 Ford F150
i put a set of pord keys on a buddys chevy, lifted it bout 1"-2". I would assume that it would lower the ford similarly.
and oh yeah... the chevy looked good but ride like ****
Old 10-16-2008, 06:06 PM
Vehicle: 2003 Ford F-150 5.4L 4x4
the chev will be able to crank his bars higher, and you'll be able to drop yours lower. i would also swap the adjuster nuts/bolts as well. both of you will need an alignment afterwards. is that the effect you are looking for?
Old 10-16-2008, 10:43 PM
yup
99' F 150 4.6 swapped 2002 5.4 and trans.
Pacesetter lth's to Magnaflow hi-flow cats, UD pulleys w/ gatorbelt, e-fans,ac bypass pulley, 9mm wires & MSD coilpacks, K&N air intake, EDGE EVO, Stage 2 Comp Cams and ported heads, Comp Cams behive valve springs, 3inch body lift w/ 35" BFG Mud Terrains on black Cregger steal rims and Eaton Posi-Unit 3.55 gears.
Old 10-16-2008, 10:45 PM
so your saying its going to ride like crap? I have heard its going to ride the same but lower, and to match the rear end by taking out the 2 inch blocks and getting lowered shocks and ill have 2inch cheap front and rear drop.
Old 10-16-2008, 11:52 PM
Vehicle: 2001 ford f150
I'd just back off the torsion bar preload using the oem keys.
2001 GEN III Supercrew, 4x4, gry interior, power bench seat with lumbar support
MODS...3" Body Lift, 315/75-16 BFG AT KO's on 16x10 Eagle 102 rims, Access roll up tonneau cover, tinted windows, chrome Westin nerf bars, SVT Lightning taillights, Pro Comp ES3000 shocks, Superchips tuner, Pioneer speakers
2005 Expedition, white Eddie Bauer Edition. MODS: 305/45-22 Falkens on chrome 22x9.5 Eagle Alloy 026 wheels, 20% window tint
Old 10-17-2008, 12:22 AM
the chevy will ride stiffer if he cranks his bars fully w/ the ford keys. wandell, he wants to lower his truck as much as he can, and can achieve a lower stance using the chevy keys as opposed to the oem.
Old 10-17-2008, 12:34 AM
as long as mine rides ok :-)
Old 10-17-2008, 12:35 AM
either way i will need an alignment so might as well make it worth it.
Old 10-17-2008, 01:01 AM
ok im assuming you understand how torsion springs work... the "spring pressure" is accually acheived from the twisting pressure on the torsion bar.
The ford keys on the chevy already creates more spring pressure and then by cranking the adjusting bolts up will increase this even more. Therefore raising the truck up, and also greatly increasing the spring pressure. Makes it so that the suspension has very little "up travel" and thus creating an uncomfortable ride... great look though
Now for the ford. I have not had first hand experience with this situation but if the effects are equaly as dramatic then you will acheive the look you are going for but will somehow sacrifice ride quality. i think.
I am VERY interested in how this works out though. keep us posted
good luck,
SouthernStyle
you will be fine, your ride will not be affected by decreasing the preload on the bars, whether you use ford or chevy keys/adjuster bolts.
Old 10-17-2008, 01:59 AM
alright...when its done ill post the pics!
Old 10-17-2008, 03:22 AM
Vehicle: 2005 Ford F-150
Not trying to flame anyone.......but ya got it backwards SouthernStyle. "Cranking" your bars has no effect what so ever on "pressure". The "pressure" on the bar is the same, no matter what keys, and no matter what height.
When you "crank" your bars, the "up-travel" stays the same. What you loose, is DOWN-travel. And THAT'S what kills the ride.
But back to FRod....you can go down until the rubber bumpstop hits the lower control arm.......with no loss in ride quality.
Old 10-17-2008, 05:16 AM
ok, well first off, i never claimed to be a suspension mechanic, i know im not.
secondly, i really am always interested to learn.
not necesarily rubuting what you said, just asking for clarification because apparently i missunderstand how it works.
this is what i thought... with the re-indexed lift keys(in this case, ford keys) the "spring pressure" is increased. and there has to be pressure on these bars or else the front end would fall to the ground. And mechainicly, the adjustment bolts get harder and harder to turn the higher you crank them, thats got to be some kind of pressure. The bars are literally twisted farther at the keys than they were stock, thus creating greater "spring pressure" resulting in increased ride height. Basicly the tortion bars are trying to un-twist their "spring pressure" at the front a-arm downward thus creating the lift. The pressure is actually so great that up-travel almost doesn't exist(put a jack under a-arm and very very little flex before lifting) which makes perfect sense since the suspension pressure has been increased exponentialy.
ok well i wasnt trying to say "this is how it works", just trying to let you know what im thinking abd give you a firm base off which to tell me how it does work.
thanks man,
SouthernStyle
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
