Home Discussion Forums Photo Gallery Product Directory Technical Articles Recalls & TSB's Product Reviews Classifieds Photo Galleries Ford Truck News Event Calendar Advertise with us
F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain (OEM) > Suspension
Thread Tools Display Modes
Old 10-11-2008, 11:49 AM
Vehicle: 2007 Ford F150
Anyone else had this problem?
I wasn't sure exactly where to post this, probably shold be in drivetrain but was hoping someone who knows more about suspesions could give me thier input.
Within the last week i have developed a leak around the slip yoke on my rear driveshaft. With the 4" rancho suspension it pulled out maybe 1.5". rancho says you driveshaft modifications are needed but my seal obvisouly is having problems and i think its due to the yoke being pulled out. Its taken a year to happen. Anyone else had anything similar to this happen or am i just the unlucky one? Anyone think i should get a spacer from fabtech? i dont know how good of quality they are
4" Rancho Lift 4.56 Gears
325/65/18 Terra Grappler M/T Mod Classic II
SI/DO Flowmaster Super 44
Old 10-11-2008, 08:36 PM
Vehicle: 2005 Ford F-150
Hey, are your Rancho blocks tapered? If not, add a shim to your leaf pack. The rear block sits at an angle, and longer blocks will actually move your axle backwards. My 5" RCD block extended my wheelbase by an inch!! I added a 4* shim and now mine is about perfect. 4 degrees would be too much for you....it will kill your driveshaft angle. I'd suggest 2 degrees. That will move your axle forward slightly as well as rotate your pinion forward and up. That should put you right about where you need to be. Much better solution that a driveshaft spacer.
Old 10-11-2008, 09:09 PM
Thanks for the input, but no my blocks are not tapered. How much do you think the blocks or shim would run? I called fabtech and talked to them about the spacer and it is supposed to ship monday.
Old 10-11-2008, 09:28 PM
If your blocks aren't tapered, then you need the shim. Add a shim on top of your Rancho block and you'll be fine. Shims are cheap, like less than $20. I got mine from Skyjacker.....but they only offer a 4 degree. There are 2 degree shims available...but I can't remember exactly where I found them. If you're interested, I can probably dig some up. They have to be for the 04+ F-150's. The universal style will not fit.
Old 10-12-2008, 01:34 PM
I just went ahead and ordered that spacer, thanks though!
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
F150Online.com and InternetBrands, Inc. are not affiliated with the Ford Motor Company
