Home Discussion Forums Photo Gallery Product Directory Technical Articles Recalls & TSB's Product Reviews Classifieds Photo Galleries Ford Truck News Event Calendar Advertise with us
F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain (OEM) > Suspension
Thread Tools Display Modes
Old 10-07-2008, 07:58 PM
Vehicle: 2001 ford f150
replacing ball joints
how hard is it to repalce ball joints on a 2001screw went to get my alingment done and my ball joints are bad all 4 of them, they told me i have to replace the upper controll arm when i repalce the top ones
Sponsored Links
Old 10-07-2008, 10:26 PM
glad you made this thread, because i was just about to make one with the same issue. hopefully someone chimes in
Old 10-07-2008, 11:51 PM
its pretty easy to replace the joints. There is a pretty good walk thru on here that someone posted that I followed. It even has pictures!
basically, you take the wheel off, mark where the upper control arm bolts are at on the bracket, loosen the bolts and break the ball joint there. the whole upper control arm is replaced with the new ball joint. Good times.
The lower ball joint, its a pain in the butt. You will need to break the ball joint loose using a pully or a hammer. you then need to remove the axle shaft from the knuckle. Then you need to use the ball joint remover from Auto Zone or wherever you rent tools from, and remove the ballloint. Then reverse alll the changes you did and its all good.
easy to do, but can take a few hours. Good Luck !
Old 10-08-2008, 07:51 PM
thanks for the help iam gonna try this weekend why so u repalce the controll are u cant just press it out or what
Old 10-08-2008, 10:37 PM
ball joints
Im a Master tech and replace ball joints in ford trucks all the time. I have only replaced 2 uppers in 97-03 f-150s. never usually bad. I would make sure they are loose before replacing.
Old 10-08-2008, 10:43 PM
yeah the guy at the front end shop said they are all bad plus my front en shakes why do u have to replace the controll arm instead of the ball joint
Old 10-08-2008, 11:33 PM
Vehicle: 1997 ford F150
it's a one piece assembly, not an option -
Old 10-10-2008, 02:43 PM
Vehicle: 2008 Ford F150
Quote:
Possibly talking about the one I posted a while ago?
Ball Joints
From a 2000 4x4
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
F150Online.com and InternetBrands, Inc. are not affiliated with the Ford Motor Company
