Home Discussion Forums Photo Gallery Product Directory Technical Articles Recalls & TSB's Product Reviews Classifieds Photo Galleries Ford Truck News Event Calendar Advertise with us
F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain (OEM) > Suspension
Thread Tools Display Modes
Old 10-05-2008, 11:19 AM
AS Leveling install ? Please!
For you guys with AS 1.5'' spacer......
Well last night I pulled the trigger and leveled my truck! The only thing I really didn't like is I had to turn my front struts around backwords to re-mount then back in the truck. Has this happened to any one else? There is only one way that the spacer seems to mount up? I marked everything before I pulled the factory strut out and putting it back together I was puzzle a bit due to the fact I had to turn my strut completely backwards to remount it due to the spacers studs being on the opposite position of the studs on the top of the factory struts. I guess this is just the way they designed the kit to re-mount back in the truck? It's a 1 1/2" spacer, thank god I went with that because the the truck sits perfectly level, anything more than that would make me sit front end high. It's just a 2wd Crew
Sponsored Links
Old 10-05-2008, 11:50 AM
Vehicle: 2005 Ford F150
You now need an alignment. Your front end is gonna be toed in..Just a lil FYI..
Old 10-05-2008, 09:49 PM
Anyone?
Old 10-05-2008, 10:03 PM
Vehicle: 2004 Ford F150 FX4
Quote:
Originally Posted by 07 Crew View Post
Anyone?
I did mine on my 2004 FX4. I didn't have to turn the struts around or anything. I can't remember, but I think the Auto Spring leveling spacers were left and right hand side specific. Could be different on a 2wd though.
Old 10-05-2008, 10:18 PM
Vehicle: 2005 Ford F-150
Ok, I haven't SEEN the 1.5 kits. But I'm guessing they did that because there isn't enough clearance to get the nuts on top of the factory studs. They re-clock the the shocks 180 degrees so that the factory studs aren't directly underneath spacer's studs. The taller kits have more clearance and don't require this.
Old 10-05-2008, 10:20 PM
Vehicle: 2006 Ford F150
yes, i am running the same kit, and thats just the way they are made. the kits arent left and right sided.... they are identicle. the reason that the 1.5" kits have to be turned 180 degrees is because it is too small...... there isnt enough room between the 2 plates to get the spacer tightened if the bolts were all aligned the same. the strut bolts would be hitting the bolts for the spacer if they were in line. so, with the bolt pattern turned 180, it all works out.
2006 F150 Screw 4X4, 5.4L...... 6" RCD lift, 35x12.5x17" ProComp Mud Terrains, Magnaflow SISO Exhaust, Fire and Ice LED bar, Edge programmer, under hood lights, glove box light, Recon LED Cab Lights.
Old 10-05-2008, 10:21 PM
hmm.... lol..... me and hillbilly were responding the same thing at the same time !!!
Old 10-05-2008, 10:32 PM
Haha....don't you just hate it when that happens??
Old 10-05-2008, 10:53 PM
Thank you guys for the response I just needed to make sure that I didn't get a messed up kit. Everything seemed to bolt in place, I just wasn't sure on the 180 degree part I feel much better and will now enjoy it The instructions that they gave me where for the 2.5 inch spacer and didn't mention the anything about the 180 degree part, they need specific directions for the 1 1/2'' so paranoid guys like me dont have to worry if thery are installed right
Old 10-06-2008, 05:18 PM
Wow, after reading these post i got a little paranoid. I just installed my 2.5" AS kit this weekend and i was just trying to remember.......was there a left and right?
04' Lariat SuperCrew- Black on Black
285/65/R18 BFG T/A KO, Nerf Bars, Bed Rails, Chrome Door Handles, Chrome Bug Deflector, Chrome Mirror Covers, Tinted Windows, Access tonau cover
Old 10-08-2008, 11:08 PM
Whats better, 1.5" or 2.5", does the 2.5 make it lean to the back cause i'm going for a level look.
Old 10-09-2008, 09:54 AM
To me the 2.5" was almost to much; it almost makes the front end sit up higher than the back...not by much. I didn't really look around to much but if you can find a 2" that is what i would suggest. I installed mine last weekend and have not gotten a chance to get the pics off the camera but i will try and get to it today and post a pic for your veiwing pleasure.
Old 10-09-2008, 12:36 PM
The 2.5" I think is a little too much, Your front will be just a tad higher, but you can always throw new blocks out back for cheap or an Add-a-Leaf, I went with the 2.5" and an AAL, the AAL was the best move.....
Old 10-09-2008, 06:56 PM
I have the 2.5 AS on my 04 Screw FX4 and it sits almost perfectly even. My cousin and I installed it for me this weekend and I measured it right away. I'm extremely happy with the look of the truck now. Got compliments almost instantly.
Old 10-12-2008, 04:50 AM
This is common on the leveling kits. If you get a kit that has a soacer made out of a solid piece of billet, it is going to have to have the studs off set from the original posetion so you have a place to put the factory nuts back on the strut. Then they put the stude in the space that et bolted back onto the truck 180 degrees from the factory ones. No big deal.
The kit I got has a steel pipe in the middle and flanges welded to the ends. I did not have to "spin" my strut to install this kit. The factory studa and the spacer stude line up with each other and due to the space between the flanges, you have toom to put on the nuts.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
F150Online.com and InternetBrands, Inc. are not affiliated with the Ford Motor Company
