Give this a shot, don't know if it's your problem but it's good to do anyways and fixed an annoying squeek I had. Spray some all purpose grease into the latches of your tailgate. Then do you doors, their pins too, whereever there's movement. I'll bet a ball joint is gone on your truck, a way of telling is jacking the front up so you can grab the bottom of the tire. Grab the top with 1 hand the bottom with the other and push/pull. If something feels loose like it has play, ball joint gone. Search "tie rod inspection" and "ball joint inspection" for complete how to's, they're easy to do as long as you're not mentally challenged!!!!
