Home Discussion Forums Photo Gallery Product Directory Technical Articles Recalls & TSB's Product Reviews Classifieds Photo Galleries Ford Truck News Event Calendar Advertise with us
F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain (OEM) > Suspension
Thread Tools Display Modes
Old 10-04-2008, 01:21 AM
Vehicle: 2004 ford F150
Exclamation 6" lift with 2.5"?
I am already running a pro comp lift with spacers. I want to go bigger without upgrading to another lift. I looked at a 12" rize and got a quote but i really can't shell that much money not including tires. I was thinking body lift but is it possible to run a body lift with spacers? would there be a problem doing that? Somebody has told me if i wanted to do that i would need to get a coilovers and then put a body lift. I am just looking for the cheapest way
black FX4
Sponsored Links
Old 10-04-2008, 02:19 AM
Vehicle: 2005 Ford F-150
Here we go again.........
Ditch your procomp 6 inch spacers
Get some 6 inch Bilstien coilovers from Topguncustomz
And then add a 2.5 inch Autospring spacer on top. Keep in mind the Autospring spacer isn't really 2.5 inches thick. If you were to add a 2.5 inch thick spacer......that would not be good.
With the Bilsteins and Autospring spacer, you'd be at about 8.5 inches of lift. Then, if you really wanted, you could add a body lift on top of that. Exactly what size tires do you want? Do you really need more than 8.5 inches of lift?
Old 10-04-2008, 03:20 AM
Vehicle: 2007 FORD F150
water under the bridge my friend, but the cheapest way, not saying the best way, is to just add a spacer on top of the spacer you already got. you'll get the lift you want for the cheapest $$
Old 10-04-2008, 08:26 AM
Vehicle: 2001 ford f150
I'd install a 3 inch Performance Accessories body lift.
2001 GEN III Supercrew, 4x4, gry interior, power bench seat with lumbar support
MODS...3" Body Lift, 315/75-16 BFG AT KO's on 16x10 Eagle 102 rims, Access roll up tonneau cover, tinted windows, chrome Westin nerf bars, SVT Lightning taillights, Pro Comp ES3000 shocks, Superchips tuner, Pioneer speakers
2005 Expedition, white Eddie Bauer Edition. MODS: 305/45-22 Falkens on chrome 22x9.5 Eagle Alloy 026 wheels, 20% window tint
Old 10-04-2008, 11:47 AM
So you could put a bodylift on top of spacers no problem. This is what i want to know. I would really like to clear 38's maybe 39's
black FX4
Old 10-04-2008, 01:44 PM
theres a guy with a gray fx4 running procomp with spacers and a body lift on 38's. cant think of his name though......
Old 10-04-2008, 11:45 PM
A body lift will not have any affect on your suspension. It doesn't matter if you have a Pro Comp, Fabtech or a stock truck.
Old 10-05-2008, 12:46 AM
no not on the lift but stacked on top of a spacer? i know you can with any lift
black FX4
Old 10-05-2008, 06:36 PM
Vehicle: 2004 Ford F-150
okay there seems to be a comfusion here.
A body lift will be putting a block persay in between your frame and the body of the truck where the body is mounted to the frame.
im assuming your talking about adding a spacer on top of the procomps spacer, which will give you 8.5" of suspension lift and if you do a body like 3" of body lift. dont stack a spacer on top of your body lift. thats just nonsense. if you stack a spacer on your suspension lift and a body likft you can be frunning 11.5" of lift and im 99% sure you can clear 40's with that.
My future plans is to get some coilovers crank them do a body lift and hopefully stick 40's on it. and yeah yeah its just for show, once you get that size tire your IFS basically becomes pointless, the CV's wont be able to do ****t.
~~6" Procomp Stage I~~37" Toyo's~~20" Hulks~~4.88's~~Flowmaster Duals~~
Not installed yet~~Bilstein 7100 Rear Shocks~Fabtech DL Coilovers~
Old 10-05-2008, 08:37 PM
is that even legal to go that high in ill? i was about ready to order a rize until i found out in WI you cant lift over 9 inches total oh well good reason to buy a f250 6 inch lift with 35's is the max i can go on the screw
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
F150Online.com and InternetBrands, Inc. are not affiliated with the Ford Motor Company
