Home Discussion Forums Photo Gallery Product Directory Technical Articles Recalls & TSB's Product Reviews Classifieds Photo Galleries Ford Truck News Event Calendar Advertise with us
F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Aftermarket > Suspension
Thread Tools Display Modes
Old 09-02-2008, 10:25 PM
Vehicle: 2005 Ford F150
Help With Fabtech 6" Install
Ok I ordered my Fabtech 6" lift and I'm planning on putting it on this weekend with my friend.. I've never done anything like this before but I'm pretty sure with my basic knowledge and direction reading skills that I can pull it off. I would REALLY appreciate it if somebody had some pics of their install and where they placed the jack stands and lift. And I would also like to know how much lift the jack will need. I have a lift that has 20" of lift and it barely gets the tires off the ground.
Please respond ASAP. I'm in high school and I want the lift on for Homecoming :]
Sponsored Links
Old 09-03-2008, 12:16 AM
get a block of wood to put on top of the jack/under the frame. when i jacked my truck up for the lift install i jacked it up under the front center cross brace and then put the stands under the frame. after that you can remove all the front suspension because the front of the truck is on stands. after the lift cross members are installed you can jack from that point and remove the stands. do the same basic thing in the rear
Old 09-03-2008, 05:56 PM
Vehicle: 2007 Ford F-150
when adding my AAL i went and bought a high lift jack. i lifted from the rear bumper and then put 2 jack stands on the frame because the high lift is not stable enough to lift your truck and someone be under it. then use the jack to lift up rear axle. then unbolt the u-bolts and put the block in. at the same time you can do your shocks. and the best part of the install. you then have a HIGH LIFT JACK! i paid 45 bucks at northern tools for mine. wish my parents would of let me install my own lift but would not let me tear apart a brand new truck
Old 09-03-2008, 06:00 PM
Vehicle: 2004 FORD F150
sorry bud, I have a shop, and used a normal lift. But if you run into any questios during install, I am more then willing to try and help ya out.
E-mail is Euroauto@sonic.net and the name is James.
(thanks Chris)
Old 09-03-2008, 06:30 PM
This is probably one of the best websites (picture-wise) that I used during my install.
http://www.celesapoc.com/truck/index.html
Here are some from my personal install. Might not be the best pictures but better than nothing maybe?? I put the jack stands under and the stock tires double stacked under the frame close to the front by the jack stands. That way if a jack stand were to fail for some unknown reason the truck would come down onto the stock wheels and hopefully save my a$$. Just take your time - don't rush anything at all and read and then re-read the instructions one step at a time. You will be fine! Feel free to message me as well if you have any questions. Did it 100% by myself with no one helping, on the garage floor, in the middle of January. lol Anways...here's some pictures.
Specs On My Setup
  • 6" Pro Comp Lift
  • 17" Pro Comp Xtreme Alloys
  • 35" BFG KM2's
  • Edge Evolution Programmer
  • Straight Pipe Exhaust
Old 09-04-2008, 09:03 PM
Vehicle: 2005 FORD F150 4X4
[quote=JD790;3359281]This is probably one of the best websites (picture-wise) that I used during my install.
You had no help. I had mine on a real lift an took 2 people
05 F150 Screw 4x4, 5.4, 3.73,6"Fabtech Basic W/Perf Shocks, Fabtech Steering Stabilizers, 35x12.50xR20 Mickey Thomson ATZ 20x9 Pro Comp 6047 Roush Grill, PHP Gryphon , Xtang RT Bed Cover, PTM LT Handles, 5" Ford Chrome Running Boards, Pioneer 7" NAV,DVD, MP3 AVIC-Z2 W/ND-BT1 Bluetooth, Infinity Perfects, Vibe 800, Kicker ZR1000 Amp, 2 10" Treo SSI, Backup Cam
Old 09-04-2008, 10:01 PM
Vehicle: 1999 Ford F-150
I did mine on my back in my gravel driveway, by myself,it was just time consuming,not overly hard.Did just like JD790 did,used jackstands,and went to town.I have a 3-1/2ton floor jack with a long extended reach,but it was a stretch.Get some blocks of wood for under your gear,to give you more height.Jack it up,block it up,then put more blocks under your jack and repeat as necessary.Lots of guys here to help you if you get stuck....it's a wealth of info here,
Magnaflow w/ duals out the back
Edge Programmer
6" Fabtech Lift
17x9 Helo Maxx6
35x12.50 BFG AT/KO
more to come...
Old 09-06-2008, 03:04 PM
Thanks for all the help guys. I've got 35x12.50xR20 Mickey Thompson ATZ's and 20x9 Black XD Spy's. I'm gonna get them mounted in a day or two and I should be putting the lift on next weekend.
Once again thanks for all the help guys. I'd really be screwed without your advice...
Old 09-07-2008, 02:51 PM
No problem man, its what this site is all about. Sounds like a real sharp wheel/tire combo. Definately post pics in here when its all said and done ! And again, post up questions or e-mail someone if ya have any trouble.
(thanks Chris)
Old 09-07-2008, 09:22 PM
Old 09-07-2008, 09:38 PM
yah post pics during the install as well too and some after i like the wheel and tire set up as well
EMAIL FOR QUESTIONS: MHOCKEY9090@AOL.COM
EXHAUST: http://www.youtube.com/watch?v=xaipuR8-uPY
Old 09-08-2008, 01:35 AM
Vehicle: 2004 Ford F150 4x4
Quote:
Strange, i had that exact same situation...
- Pioneer Premier - US Amps - Image Dynamics - JL Audio - Raammat - Secondskin - KnuKoceptz - SOON--> Stereo Integrity
Old 10-18-2008, 11:38 PM
Vehicle: 2002 Ford F150
I have a 2002 F150 crew cab. I want to put a 7.5" lift, but it can only fit 35" tires. I want to go with alittle bit bigger tires. Will a leveling kit do it? What size tires could it fit ? If not what can I use and what size tires can it fit? Thanks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
F150Online.com and InternetBrands, Inc. are not affiliated with the Ford Motor Company
