you should be able to lay out as much as you want as long as you clearance everything in the way.
baggin a truck with the twin I beams shouldnt be that tricky as they still use a spring.
Just make sure you clearance and reinforce everything you cut. i had an old i beam truck once but i cant recall how the clearance was up front. From what i do remember though, the front suspension articulated quite far stock.
i will tell you though, with those i beams your gonna have massive camber and probably eat ball joints like crazy.
If you had the skills i would say to just do a more common and trouble free upper and lower control arm setup but that would require exstensive modification. Quite honestly if your asking about how to bag it, i doubt youll be able to tackle a full front suspension graft.
In the rear a four link will do just fine, just make sure to triangulate it well and with the long bed, you can probably make those four link bars long as hell, meaning you can get massive lift with a great ride out back if you place the airbags just right.
