Home Discussion Forums Photo Gallery Product Directory Technical Articles Recalls & TSB's Product Reviews Classifieds Photo Galleries Ford Truck News Event Calendar Advertise with us
F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain (OEM) > Suspension
Thread Tools Display Modes
Old 08-19-2008, 11:23 AM
Vehicle: 2005 Ford f150
Another bilstein 5100 question..
So i already hav these shox on my 05 f150 and iv decided that i want to adjust them 2 in so i can clear bigger tires i just got. When i took it to my local 4x4 shop they said that these shocks cudnt be put on a 2 inch setting to get mor lift out of them?? Also are there any other places where you can hav these shocks put on the 2 inch setting besides 4x4 shops? thanks
Old 08-19-2008, 01:45 PM
Vehicle: 2005 Ford 150
They have to be removed from the truck to adjust.
Old 08-19-2008, 07:03 PM
I know u cant do it with them in the truck. But they said it cant even be done period.
Old 08-19-2008, 09:29 PM
Vehicle: 2005 F150 Fx4
Quote:
Do you have spacers installed? If you have spacers installed they are only looking out for your best interests. If you don't have spacers and your shocks are truly 5100's, they can be adjusted off the truck.
Old 08-19-2008, 09:35 PM
Vehicle: 2002 Ford F-150 5.4L
You also don't have to go to a shop...you could do it yourself at home, but as mentioned, they have to come off the truck and you'd have to rent a spring compressor from Autozone...none of which is a big deal. Also as mentioned, make sure they truely are 5100's. Look through the coil spring at the body of the shock. There should be two additional grooves in the shock body that run full circle around the shock. I'm not sure if you can even see them but take a look. If you have those grooves, those are the grooves for the spring perch ring, and thus you truely have the 5100's.
'02 F150 XLT 4X4 SCrew. 5.4L
K&N FIPK
Flowmaster 40 si/do Exhaust
325/70 16 Nitto Terra Grapplers
16X10 MB Motorsport wheels
4.10 Gears
Rancho 4" lift
Edelbrock Extreme Travel Shocks
Autometer Carbon Fiber Oil/Trans Temp Gauges
Carbon Fiber Interior (www.dash-kit.com)
Peterson Fluid Sys. Remote Oil Filter
Mag-Hytec Diff cover
FTVB
Troyer Performance Electric Fans
Underdrive Pulleys
Amsoil Fluids Throughout
My SCrew'd Garage
Old 08-19-2008, 09:45 PM
Vehicle: 2006 Ford F150
two additional grooves? My 5100 struts only came with two grooves period... a stock setting and a 2" setting....
did not mean to highjack
I'd start by verifying they are the 5100's...
Cheers
Nem
Old 08-20-2008, 02:40 AM
OK, yea I think that could be right also. I thought the 5100 for this truck had a 1" and a 2" ring, but could be wrong.
K&N FIPK
4.10 Gears
Rancho 4" lift
FTVB
Underdrive Pulleys
My SCrew'd Garage
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
F150online is not affiliated with the Ford Motor Company.
