6 inch lift with a V6?
I have a 2007 reg cab V6. I have yukon 4.56 gears,and im just not satisfied wit the 2.5 level kit and aal. I want to go bigger. 6 inches is my only option witha 2wd. my question is how bad would my truck be with that size and a V6, even tho i re-geared. btw im keeping my 33's until they are bald, cuz they werent cheap. holla back
33's on a 6" is gonna look horrible. but it is doable for the mean time.
and since its a 2wd it wont look as bad as a 4wd with 6" and 33's.
My truck is a 4.2 with 36's and its fine i get close to 15.2 mpg which isnt bad. And thats on the stock 3.55 LS.
when i go up in gears ill be much happier though.
yes i finally got i finished. it was tough because i worked 4 14 hour shifts on the last 2 weekends.
but shes running i need a new alternator but thats can wait for the time being.
and my motor really wasnt hydro-locked it was still running. But when the number 2 cylinder tryied to compress water it bent the rod! that was right before it cut off! NORMALLY the truck will flood out and cut off before this happens.
