Thinkin bout lifting
Old 08-08-2008, 03:56 AM
hill2107's Avatar
I have a 06 4x4 scab with 20x9 MM951's (5.71 BS) w/ 35x12.50 Toyo M/T's. Thinkin bout a suspension lift, maybe 4-6"s. What brand would you reccomend me buyin to run the same setup I have now?
Old 08-08-2008, 09:13 AM
ATOM's Avatar
i got a rancho on my truck and love it, just make sure the lift kit you choose will work with your rims (backspace isn't too much)
Old 08-08-2008, 10:25 AM
Impact9's Avatar
procomp, fabtech, bsd, superlift, rancho, rize, and probably a few i'm forgetting all make lifts that are solid. BSD is probably the best since they have a awesome warranty but cost more. Pro Comp is probably the best value though.
Old 08-08-2008, 12:02 PM
wandell's Avatar
Fabtech, Rize and RCD are probably the best lifts.
Old 08-08-2008, 12:20 PM
4X4AUTIGER's Avatar
X2 in that order
Old 08-08-2008, 02:19 PM
efuehrin's Avatar
I think there are some lifts out there that don't drop the torsion bars down.
That would be the way to go. I always worry about bending one when I'm off-roding.
Plus it would look better with them stuck up higher.
Edit - sorry just saw you have a 06. No torsion bars.
Old 08-08-2008, 07:24 PM
hill2107's Avatar
Thanks everyone ive been leanin toward fabtech form the beginning. just wanted to see everyones opinion
Old 08-08-2008, 08:00 PM
06yz250f's Avatar
its bds. not trying to correct you just making sure he doesnt get confused.
i have the bds. i would highly recommend it. the reason i stayed away from pro comp is b/c the shop told me warranty on them sucks. i payed $2100 installed. it uses a spacer like the procomp.
next step up would be a fabtech from bds or pro comp. probly a few hundred more bucks but it comes with new shocks up front i believe? correct me if im wrong any one.
Old 08-09-2008, 11:40 AM
CHUCKO1404's Avatar
Fabtech OR Rize
Old 08-13-2008, 11:04 AM
supachargd2k5's Avatar
4" - Rancho
6" - Fabtech
6"+ - Rize, Procomp, Fabtech
Old 08-18-2008, 04:37 PM
IDNC76's Avatar
make sure u can reuse your wheels, (unless you want new ones) thats one reason i went with a body lift
Old 08-18-2008, 11:55 PM
thorherc67's Avatar
go with rize or fabtech
Old 08-19-2008, 04:16 PM
I'm going with a 6" Fabtech from all the research and feedback I have got on them.
Quick Reply: Thinkin bout lifting
