fit 285/75/16
the body lift should be enough. i had just a 2" coil spacer on my old 2wd 97 and with stock wheels i coulda fit 285's. if you have aftermarket wheels you might need to trim a little valance or the bottom of the back of the fenderwell but you should be ok. wandell or someone will chime in and give you a set answer.
