Fabtech 2wd 6" Lift Question
Old 08-06-2008, 12:56 PM
saakers's Avatar
I started intalling the Fabtech 6" lift on my 2wd 2008 Screw last weekend. When I got to the back I noticed they only included a 2.2" rear block and no new rear shocks. Why is the rear block only 2.2"? I've seen in previous posts that some guys recommended buying the 5.2" rear block. Is the 2.2" block for a "Pre-runner" type truck?
Old 08-06-2008, 12:59 PM
wandell's Avatar
Yeah, the Fabtech lifts usually give you a prerunner look, but I thought 4 new shocks were included.
Old 08-06-2008, 02:38 PM
_cashel's Avatar
Just curious with the NBS trucks and the Fabtech lifts. Is the 6" 4x2 Fabtech truly a 6" lift (will it sit lower than a 6" 4x4) or is it built like the old 4x2 Fabtech where it's a little more lift, but sits at the same height as a 6" 4x4?
Old 08-06-2008, 04:55 PM
mSaLL150's Avatar
A 4x4 will sit higher than a 4x2, both with Fabtech lifts.
For some reason, the 2wd kit has the front a little higher than the back, where the 4x4 kit has the truck perfectly level.
Old 08-06-2008, 05:03 PM
chazf150's Avatar
The kit comes with 2" rr in back. I upgraded my with 5"
My kit also came with rr shocks.
Old 08-07-2008, 10:47 PM
thorherc67's Avatar
^^ same as above i upgraded to the 5 inch block
Old 08-09-2008, 12:03 PM
evillesi's Avatar
you need to upgrade to a 5" in the rear. what tires will you be running
Old 08-09-2008, 12:48 PM
Davespeed's Avatar
X2 and I need a 1.5" lift shackle
Old 08-09-2008, 09:01 PM
thorherc67's Avatar
i got the 2.5 inch AAL it was actually more like 2 but it sits really nicely now
Old 08-10-2008, 03:16 AM
wxscpo's Avatar
Yes upgrade to the 5" block, here's a link to it.
http://performancelifts.com/cgi-bin/cart/FTSBK52.html
Old 08-10-2008, 07:42 PM
saakers's Avatar
Thanks for all the help. I bought the 5" block and installed it yesterday. It now sits perfect. Now I just have to decide which wheels to buy.
Old 08-12-2008, 02:22 PM
cortinas's Avatar
saakers-once you installed the block did you have to put some sort of driveshaft spacer? or is the drive shaft long enough? thanks
Old 08-14-2008, 02:17 AM
wxscpo's Avatar
I know you didn't ask me, but since I have the same setup as saakers I'll go ahead and answer. Drive shaft is plenty long enough, no spacer needed.
Old 07-31-2011, 05:52 AM
bay150's Avatar
I ve been looking into whether i need a spacer on the rear diff.
I found most guys said they did, but WXSCPO didn't? Are you still running it that way with no issued WXSCPO?
Old 07-31-2011, 03:21 PM
06yz250f's Avatar
he sold his truck just as his sig says.....
Quick Reply: Fabtech 2wd 6" Lift Question
