Lifting 6"... DIY?
Lifting 6"... DIY?
Looking to pick up a fabtech 6". i have basic mechanical knowledge with cars and trucks. Can i do this by my self in my garage? Anything special that i need? Any tips and tricks? Also, how are the instructions that come with the lift, if any.
Just wondering how easy it is to do, before i buy it.
Thanks for your help.
BTW 2004 Screw FX4
BTW 2004 Screw FX4
i dont have a fabtech but everyone who has installed it on their own recommends to do the same because then you know more how to work on your truck and gives you the satisfaction. you have to cut one bracket which i believe any 6" lift requires but its a bracket not the frame. i think that bracket is cut for the subframe clearence but not a 100% sure so dont qoute me on that. the kit has instructions. the rear end would be and is easy to lift. if you have the time you and a buddy do it on a saturday. it will take all day and possibly the next depending on how you work. the instructions are on fabtechs website under tech if you want to look them over
I to installed my 6" lift myself and it was not very hard to do, I had access to air so that helped out alot but you could do it with hand tools, if you do it yourself you will have a better understanding of how your suspension works and how to fix it if something breaks plus you`ll have the satifaction of knowing it`s done right and not going to fall apart when driving down the road, if you need any advice there is alot of people on here that have done they`re own installs so feel free to ask questions if you need help and good luck with the install
Yes the kit comes with blocks for the back. You may also want to add a AAL, I did. But the blocks will be fine if you don't crank the coils up to much. Unless you like the bulldog look.
i agree with all the rest.... do it yourself... mine took me and a buddy just over 10 hours, so its a long day. but well worth it !! you will definately want air if you can....especially when you cut the bracket where the stock rear crossmember goes. (this provides clearance for the front axle tube). a air powered cut off wheel will help big time. otherwise all the instructions are pretty straight forward, and we are here to help if you get a snag. goodluck !!!
This makes me feel a bit more confident if I decide to install my own with a friend. How much would the average shop charge for the labor and how quick could it be done?
Your truck looks f'n awesome! What kind of fuel economy are you getting?
