Two quick questions while installing body lift..
I've read you don't need to remove the radiator or hoses during the installation. Does this include the transmission and power steering cooler as well?
Also, in the directions it talks about the 4x4 shift boot and transfer case linkage. I've got the electronic 4x4 shift on the fly, do I need to do anything for this?
I'll post more questions as I go along with this I guess.
I've got everything just about finished. I still need to deal with the shroud and bumpers, and drill the frame for the safety cables.
One thing though. In the directions, after it tells you to mount the bracket for the ground cable on the passenger frame, it tells you to mount some other bracket to some location on the passenger front part of the frame. The picture looks like crap and I can't tell where it's located, and it doesn't look like I need it anywhere on the truck. What is it exactly?
Oh and I mounted the 38's on there and damn , it looks insane. Pics tomorrow when it's finished.
not sure what it is we're talking about here... i can't remember anything else on the passenger side other than the ground and the safety cable. it refers to the chassis ground? is that it? also, did you put the new bracket on the transmission? i originally did not, and wound up snapping the gear selector cable, and had to replace it.
man you got to get some pics of those 38s tommorow I`m dying to see what it is going to look like
not sure about that other bracket your talking about but if you cant find somewhere to put it I wouldnt worry about it I had some parts left over when I did my body lift although I cant remember what exactly they were
Also here are the instructions i'm using HERE
Scroll to page 24, that's the bracket I'm talking about. It's the one after the first ground strap bracket.
I'm headed out to work on it now, so i'll get some pics later on.
