4" 2WD lift
what are you looking to do?if you want to lift then i would recommend a 6 inch fabtech lift kit.or if you are looking to save some funds you can get a add a leaf put on and since you have a spacer already get a 3 inch body lift.that should yield a good amount a lift.and then you will have height added from new wheels and tires.
with my spacer and wheels and tires alone i am 4 inches higher than stock.i hope this helped out.the good thing about that set up is later if you want to go even higher then you get the suspension lift but the bad thing i heard was a body lift has some things that may need to be replaced if you have to remove it.
btw i have an oops,i didnt read all the posts but i see someone else already recommended the bodylift i apologize.
