1" rear spacers ?
1" rear spacers ?
Okay, so thankfully I didn't get a 2 1/2" inch front leveling kit.
Instead, I got the Bilstein 5100's with the 2" lift (and I absolutely love the way my truck feels / handles now).
But here's my dilemma; I put all four stock tires + wheels in the bed, under my bedcover (for lack of a better storage place at the moment) and then I started thinking > Well, those probably weigh about 250 lbs, huh ? Well, that should closely aproximate 100 to 150 lbs of fishing tackle (when you include 1 or 2 deep cycle batteries) in the bed, and a light trailer, with a 100 lb tongue weight on the hitch.
So, I go out and measure from my wheel wells to the ground, and find that my rear end is sitting 3/4" lower :-(
I can live with completely flat.... or slightly higher in the rear, but I don't want any bulldogging at all.
So, even if you skip all of the above, what is involved in those 1" rear lift kits ? Spacers and what else ? Do they include new U-bolts ? What should I expect to pay for that kit ? How much work to install ?
Thanks,
Fish
PS, The reason I want the truck to sit at the right height "with" the trailer attached, is that the trailer will end up being attached to the truck 98% of its life.... plus, most times when I'm actually driving it, the bed will be full of fishing tackle....
Thanks,
Fish
Ford already has a block in the back, 2" block I believe, so the easiest solution would be to replace that with a 3" block and get longer U bolts.
You can find the blocks & bolts seperate or buy them as a kit from most online offroad shops. I would get themn as a kit so you know everything is the right size.
Add a leaf is another option but requires alot of work to get the spring pack apart and back together. I also have found that add-a-leafs can damage your leaf packs over the years and makes the ride considerably rougher than factory.
Installing the larger block, if you go that route, is pretty easy. With 2 people and a 6 pack you can expect an hour or so if your reasonably mechanically inclined or maybe 2 hours if your not.
Ehh, a rear block with U bolts should cost maybe $60 max. Im sure you could find them for a bill, but a quick search online turned up plenty of places selling them for 50-75. I did one on a Nissan Frontier by myself in about an hour. To make the job easy have 4 jack stands and 2 floor jacks. Make sure the jackstands can raise up pretty high also
Hey fish.
Dont you have a 2wd? If you do, then you do not have any blocks in the back. I belive only 4x4 trucks came with them. I know auto springs has a 1.5inch rear block for about $116.00 and another company has a 1 inch for $99.00 I think. This would be your best bet unless you go with a aal.
