Front End Alignment specs
Help me make some sense out of these numbers I received after having a front end alignment at my local dealer. This report was on the dash when I picked up the truck this afternoon. I know what camber/caster/toe in is all about, but it's the actual numbers I have questions about.
The report has settings for Front: Left; Front: Right and Front
Front: Left has:
Camber Actual -0.2 and specified Range -1.0 0.6
Caster Actual ----- specified Range 3.6 5.6
Toe Actual 0.12 specified Range -0.05 0.20
Front: Right has:
Camber Actual -0.3 specified Range -1.0 0.6
Caster Actual ---- specified Range 3.6 5.6
Toe Actual 0.10 specified Range -0.05 0.20
Front has:
Cross Camber actual 0.1 specified Range -0.8 0.8
Cross Caster actual ---- specified Range -0.8 0.8
Total Toe actual 0.22 specified Range -.10 0.40
All measurements are in degrees of angle.
Does the 'actual' value indicate what the settings were after the alignment? I think it does but would like confirmation. I think the range just shows the acceptable range, true? and finally are these settings pretty much neutral for an unmodified super crew with 5.4
Front: Left has:
Front: Right has:
Front has:
check the lower controll arm bolts and see if they have been loosend and adjusted, which is very hard to do without using a camber kit. i bet all he did was set the toe and collect the dough... from what i can see the measurments look good other then there is no caster measurment.
