6" lift for a 08 2WD Reg cab
I am researching 6" lifts for a 2WD and I thought I wanted the Fabtech but I really don't want to grind anything off my truck. I want to be able to go back to stock relatively easily if I need to. Is there a 6" lift for the 2wd that does not require cutting? I want bolt on.
yeah but when you put bigger tires on, that gives you even more lift. lets say you go from 31" tires to 35" tires, leaving 4" taller tires meaning 2" above and 2" below the axle, so 2" more lift. 6" + 2" from tires = 8" of total frame lift. Thats a lot higher than your truck is now.
Fabtech is a little more expensive than procomp but much higher quality. It is less expensive than a lot of other lifts too. Procomp just puts a fat spacer ontop of your stock shocks, while fabtech replaces all your shocks with longer ones. I'd go with the fabtech for sure.
send a PM to member crash_lucky13 he can get you deals on lifts even lower then what you think....
