6" suspension lift issues
Im looking into getting a 6" suspension lift for my 06 ext cab f150 4x4 5.4. I have a pretty good mechanical background and pretty much every tool I can think of. what Im asking is about how long would it take the avrage guy to install it from start to finish...are we talking a weekend or a few days? how technical does it get? and what "after install" procedures do I need to get done to it..alighment...etc. so anyone out there who has done this, let me know all the biggest pain in the a$$ situations you encountered with your install please. thanks
it took me not even 2 days to put my rancho on after all said and done, would i do it again, maybe. it was easy getting stuff off with only 7000 miles on it, but more time consuming than anything. make sure you got a helper. the worst part of the whole thing is taking the upper diff bolt off, what a PITA. if you have any doubts, i'd let someone else do it. just my opinion.
If you have another set of hands, some mechanical capability, and are familiar with suspensions you can knock it out in a weekend. Air tools are a big plus! Make sure you have a 12mm 12-point socket for the axles and front drive shaft bolts. Also a 30mm deep socket for the nuts on the lower shock mounts. As stated above the upper diff mount bolt can be a pain, but you can make it easy by loosening the steering rack and go at the bolt from the front with some long extensions. Lifting the front is what takes the most time, you can lift the rear up real quick! You'll need an alignment when your done.
my lower shock bolts were bigger than 30mm, i dont know what size they were, but i just used a big cresent wrench. and make sure you have a torque wrench and use loctite. i didnt loctite my caliper bracket mounting bolts and one came loose one day on my way to work, nothing major just scuffed the inside of my rim, but it could have wrecked my day.
