towing with a lift?
towing with a lift?
I have a 2001 f150 supercab 4x4. I would love to get a lift kit since i could really use it for some of the places i need to get to for work. also would love to start trying to do some off roading. I was wondering if it's possible to get a 4 inch lift and still be able to tow when needed and what would be the best tires for it when in snow. Any help would be much appreciated. Thanks in advance.
I got a 3.5" lift on 35's and tow a 6k 2 horse regularly...no problems I didn't even re-gear (probably should though she's not that great on on-ramps lol) but other than that no-problems w/ a 3.73 LS. One thing you gotta watch out for is Diff-Temp get the gauge its worth the money, that and tranny temp. Just bigger tires, more mass to move, so its gonna run a little warmer. Main problem I had was finding a drop-down to fit (8" works for 5-6" of lift in the rear) and w/ my 2" AAL in the rear I sit butt up a little bit buts thats because its normally got some weight in the back then it levels out.
~Phil
"Semper Fi"
~Phil
"Semper Fi"
In the winter i operate snowcats at our local ski resort in northwest new jersey. In the summer we use trucks to do trail maintenance. there are a lot of rocks and areas that are washed out from snow melting. there are a few company trucks but most of us prefer to use our own since gas is compinsated for. we mostly just tow small loads though.
towing with a body lift in my opinion would be better, no blocks to deal with no axle wrap. your trailer hitch is just going to stick down a little more, you will still have a loss of power from the larger tires unless you do a gear swap but thats anything you put larger tires on. if your going to do a body lift you need to get gap gaurds or make a set otherwise it just won't look right
