holding the weight
put a bigger block under there. DO NOT STACK THEM! For example if you have a 2'' block now (probably) you could put a 5" one under there to yield a total of 3'' lift. you could also go w/ one slightly smaller if you do not want that much lift. also, make sure you get the correct size u-bolts for the new block.
i wouldn't do anything with blocks, your not actually increasing what the truck can take instead just keeping the bumper from hitting the ground. maybe try someting like this http://supersprings.com/#pulldowns
i don't have any experience with them but have heard good things about them.
i agree with the air bags.... they are aewsome.... allow for adjustablilty regarldess of load in truck, and easier to install than aal. however, down side is pricing.... looking at just over 200 for the kit, and then another 200 for a compressor (not needed, but nice). i love mine, they are very handy.
air bags would be the way to go, but if cost is a factor and you only occasionally haul some mulch etc...than an add a leaf may be your best option.
You can probably fit 2 yards of mulch in your bed, but picking up a yard and a half may be the best thing so you arent beating your truck
What kind of trailer are you pulling? Maybe the tongue weight is wrong?
