Something is LOOSE!
Something is LOOSE!
It's been driving me crazy. And it's got progressively worse. Now it's bad. Something is loose in the front end or steering. (no steering play though) I can feel it through the steering wheel; a series of clicks and small jolts through the steering wheel while turning, accelerating, braking, going over bumps, seems like any time the suspension articulates. 75K on the truck, new lower ball joints, and the most frustrating part is that I had it into the dealer and paid for a front end inspection about 2K ago and they said only thing that was wrong were the lower ball joints, and I got those replaced! Still doing it! What sort of things loosen up in our front ends typically? It's going into the dealer tomorrow, but I need your ideas since sometimes they need help finding the problem too! Thanks.
'03 150 4X4
'03 150 4X4
Stabalizer end links go bad rather quickly in these trucks... after you replace them to polyurathane they will last MUCH longer. Have you checked your steering linkage? If you look under the dash its right there check and see if its loose.
you need to get under the truck and look at ALL the bushings before you take it back to the dealer, or you might end up paying for something you dont need.
Hey, just thought I'd share with everyone what it was. I got my truck back from the dealer. It was the steering shaft. It was apparently loose somewhere. All they had to do was take it out, grease it, and put it back in and the issue has disappeared. We'll see if it lasts. It cost me about 70 bucks to have them fix it (their time) but I was so annoyed by the problem I really don't care at all!
Well son-of-a..... the problem is back. The solution lasted maybe a day, then the looseness came back progressively. I guess I need a new steering shaft. The dealer wants 170 parts alone, so it'll be like a 300+ dollar job. Is this something I could do myself? I feel like this is a really stupid thing to have go on a truck, espescially with 75kms on it.
what type of lift are you running? if you have lift springs and different uppers or just any lift really without a dropdown crossmember is worthless on the 97-04 trucks. the second the spindle gets lifted at all it changes the steering geometry and that problem will never go away. i had lifetime warranty parts and would replace all my steering parts every 10000 and the problem would never go away simply because of the front end design. you need a new lift, one that has a drop crossmember and leaves your tie rods in the stock andgle
