Is this 3" lift Good
3 Inch Lift Kits - 2005 F150 FX4
KEY FEATURES Platinum Series Coil Over
Rear Leaf Springs Massive 2 Piston Bore
Huge 22mm Piston Shaft
Off-Road Race Inspired Wafer Valving
Heavy-Gauged 3.175mm Steel Body Wall
PRODUCT HIGHLIGHTS
No grinding or cutting of the front differential housing is necessary.
Includes New Softrideฎ Coil Springs.
Provides Increased Wheel Travel.
This surprisingly simple yet completely durable suspension package, allows the rack-and-pinion steering and front & rear sway bars to be left in the stock positions for precise steering response. There is also no need to modify or replace the drive shafts... plus it makes way for larger 285-75Rs tires.
Shock Options:
Hydro Shocks: Hydraulic fluid contents, recommended for mild to moderate off-road use.
Nitro Shocks: Nitrogen filled, recommended for moderate to extreme off-road use.
PRODUCT HIGHLIGHTS
Shock Options:
