rear lift
rear lift
so right now i have 3 inch lift spindles and 2 inch blocks in the back,i just ordered my 2 inch front lift coils and now i need to lift the back another two inches. i dont want to go to a bigger block for fear of spring wrap. will an add a leaf make the ride to ruff? i was thinging a 2 inch shackle with helper springs for when i have my dirtbike and what not. also will 4 inches of lift in the back require me to buy longer shocks, and will my drive shaft be alrite or do i need an extension/ or those angled shims? on a side note will 5 inches in the front and 4 in the back clear 35s?
my dad put a 2" aal on his ranger when he lifted it and it was really really stiff. imo the suspension in the rear is already too stiff unless you constantly have a load back there. i would see if there is a shackle to lift it or a 3" block. stock 4x4 got a 2" block so i dont think a 1" taller block would make that much of a difference and would probably put you back to level with 5" in the front
