6" fabtech install issues
i hate to go out of my other thread but i'm not getting a response there so i figured i'd make another to get more attention. i installed the crossmembers and went to drop the diff, bolted it up to the front crossmember and went to bolt it up to the rear crossmember and the holes do not line up. i'm thinking it has something to do with the fact that i had to grind a lot just to fit the front crossmember but i dunno. anybody else run into this or have any suggestions to fix it go ahead and let me hear it. thanks,
Justin
Justin
Justin
Justin
I had to have all the bolts loose also (very loose) on the crossmembers and had to pry on it a little to get it lined up.Thinking I had to pry more on the front than the rear one and then knocked the bolt through. I could not put them through without a little help from a hammer.
Edit: Thinking a little more about it I used a large screwdriver in the rear hole to get it lined up and started the bolt through as far as i could. Then used a hammer to knock bolt rest of way through
