Front
The torsion bar adjustment keys are a bad idea. They just allow you to put more preload on your torsion bars than you can with the oem keys, which will lead to premature ball joint and cv joint wear. I'd suggest just cranking up the torsion bars with the oem keys enough to level your truck. If you want more height inexpensively, add a body lift.
