3" BDS Body Lift
Are you looking to install it on your 04? Or has anyone out there installed this BDS kit yet?
i dont see how it would be any easier, you would still have to pull up the carpet and the rear seat to get to some of the bolts.
All Body lifts get their lift the same way so wouldnt the process be the same... just a different product?
I hear you guys. I was more so curious to see if they tell you to still pull the radiator to cut the fan shroud, and cut the front frame back under the front bumper like the PA kit. Also, if they tell you to lift the brake module.
I would imagine the install would be the same but I was able to avoid those steps on both installs I did.
Then again, I only installed them on a 00 and an 03. Not on any 04+s. Just wonderin' ... I'll probably google the kit and take a look.
