Bilsteins or Leveling Kit?
Guest
Posts: n/a
After much thought, I am going with the Bilstein shocks as if I went with the leveling kit. I would be maxing out the shock and having to get new ones anyways. Plus I dont like the look of a huge spacer in the front. That and it will ride better as well. Spend the extra money and get the Bilstein your front end will thank you for that.
I have a leveling kit. On my next truck, I'm getting the shocks. A lot of the members here favor the AutoSpring leveling kit. But none of them have offered any specific articulable facts as to why that particular product is in any way superior to others, and the best argument I've heard is that it is priced right. To me, that's not a good enough reason. It is not of superior design. It is not composed of a superior metal. It does not enhance the ride or operation of the vehicle. All it is, is a cheap way to add a few inches. My leveling kit choice was a leading manufacturer's 2 piece polyurethane kit. It is a lot more difficult to install since it requires you to take apart the coil springs and have a spring compressor. Professional installation is recommended, which makes it more expensive to buy and place into service. However, with the polyurethane, you don't have the fatigue of metal on metal rubbing which occurs by stacking a metal spacer onto your suspension. With 20/20 hindsight, I feel that you gain a more efficient suspension modification and a better than factory ride with the adjustable shocks. At this point, consider what a few hundred dollars difference is worth on your $40,000 truck.
I would recommend the Bilsteins to anyone......I've had them for about 2 months now. I considered the spacers, I felt they were just a cheaper way to get the lift, but you would probably have to replace the stock shocks at some point, so why not do it all at once..........plus the ride is such an improvement.
Got mine at topguncustomz.com also........Great company to deal with!!!!
Okay then, just a couple questions....
about the Bilstein shocks.
1) MeekinIt said $379 for fronts + rears..... So could I get just the fronts for now ? (rears later, if I were so impressed by the fronts) Only about $200 ?
2) Would these be as easy to install, as "any" normal shock absorber ? And easy to adjust height ?
3) Are they a totally variable height adjustment design ? Or, like +1/2", +1", +1 1/2", etc.....
If these could actually improve my ride, plus give me just the right amount of lift I need, for a nice leveling, and were better for my truck, I'd probably pay $200, instead of $100 for a spacer kit......
Anybody ?
Thanks,
Fish
Anybody ?
Thanks,
Fish
I agree. Like I said, the advantage of the leveling kit is price only.
As for combining the two, that would make no sense at all. You can't run a leveling kit and the Bilstien's with the preload cranked up because it would destroy the front end, if you could even get everything bolted back together. And, running a leveling kit with the Bilstien's preload at stock height would just be a waste of money, even if the leveling kit is only $80.
I did not know they made them for the rear also. A 2" lioft all around for $400 is not a bad deal and would allow you to run 35"s if you have a 4x4 model. I never did like the leveling kit idea because it just seemed like a cheap "solution" that could cause issues later down the road. The Bilsteins are about the only option I would consider
