1997 f-150 4x4 thump/pop in front end
Jack the front end of the truck off the ground. Grab the tire at the top and bottom (12 &6 o'clock position) and try moving it back and forth. If you feel any play, you have a bad ball joint(s). Now grab it on each side (3 and 9 o'clock position) and shake it again. If you feel any play the tie rod ends are bad.
