Lift spans sanity check
Lift plans sanity check
Keep in mind that I really don't like to do things half assed, hence the equipment I plan to buy. However, I do have a budget, so let's see what I can come up with. Also keep in mind that in NJ I can't lift more than 9" above stock, which is the reason I'm going with a 6" and not an 8" lift.
For the suspension components themselves...
Wheels and tires
Some options that I'll probably be adding later because I don't want to spend the money now:
The 6" lift w/ the 35" tire would give me about 7.75", and then I can use the adjustable coilovers to push me closer to my 9" max. I also may either add an AAL or block in the rear to push the rear up a bit more (looking for some input and options on that).
Any major issues with this setup I should be looking out for? This is my first attempt to lift a truck, and I know there is a plethora of knowledge here that will stop me from making a stupid noob mistake.
- Fabtech 6" lift stage 1 kit
- Camburg adjustable coilovers (for the 6" lift) for front
- Sway A Way RaceRunner resevoir shocks (14" extension)
Wheels and tires
- American Eagle 064 20x10 (4 5/8" of backspacing)
- 35" Nitto Terra Grapplers.. forget the exact size
- 4.56 front and rear, of course...
- Detroit Locker for rear diff
- Eaton E-locker for front diff
- Mag-Hytec diff covers and tranny pan
- Camburg upper control arms
- Fabtech steering stabilizer (if the steering sucks)
Wheels and tires
Wheels and tires
Uggh I may have some issues, silly NJ laws again.
I'm running 20" OEMs right now, and NJ requires you to have a fender that covers the full tire tread. So doing the math, it would seem if I went with the eagle 064's 20x10 and 4.6, I would be sticking out about 3.5" further than stock wheel plus the additional 1.5" of the 12.5" tires? Is my math correct?
Basically, since I need to have the fender flairs to cover the additional tire, and since I can only seem to find flairs that add 2" coverage, I wouldn't be able to cover a 10" rim, at least I think?
I don't know the exact measurements of the 20" rim, but I know I read the OEM wheels were 7.5 w/ 5.5 of backspacing. Is it the same for the OEM 20s?
i think fender flares ruin the look of a nice wide stance imho
NJ laws suck, do what you want though, it will be worth it in the end.
as for inspections, see if you can "work out a deal" with a local gas station
i ve had tints on the front windows for over a year , with no problems
I think I'm going to have to go with a 20x8.5 or 20x9 wheel with 4.5-5" backspacing, then with the wheel I can come in about 2.5" beyond the current tire which I would be able to cover with the bushwacker fender flares.
Kind of looking for confirmation my measurements are correct, I am assuming a lot about the OEM 20's.
heck ya ! as long as you only stay on the street !
Their super hard compound make it so they don't "self clean" all too good. The gum up pretty quickly then basically turn into big ole donuts.
Great tire for a weekend warrior, who will be seeing a lot of pavement (like these trucks) but by far NOT the "best" tire out in the off road community ! Just so ya know
Great tire for a weekend warrior, who will be seeing a lot of pavement (like these trucks) but by far the "best" tire out in the off road community ! Just so ya know
