Grease ball joints
Originally Posted by Adam06FX4
you cant. there is no way to get grease into the joint. your better off to just replace them. there 8 years old anyways...
Used a needle adaptor and greased the upper and lowers. Squeak is gone and I'll delay the inevitable. Thanks guys! On a side note, the bushings where the control arms connect to the frame are dry and cracking. Can I replace these without replacing the original control arms and ball joint?
When you greased them, did you push the boot while it was filling with grease to compact it in there and all around? Since you joints are newer, I hope you cleaned the boot and sealed the hole you made to insert the needle. I think silicone would work.
