03-05-2008, 11:49 PM
Garage is empty, add now
Vehicle: 2006 Ford F150
Lift?
IF you guys had a 2006 f150 2wd would you get the fabtech 6 inch with coilovers or the 7 inch cst. I want to get the most possibe lift to fit moto metal 951 20x10 with 4.5 bs and 35 by 12.50 tires without rubbing. Im trying to get away from using a spacer. I want my angles to be ok. Thanks
03-06-2008, 02:31 AM
i would do the coil overs. you can crank them to get 8" of lift from the 6" kit. also, i believe the rcd kit just uses a big spacer like the procomp kit does
03-06-2008, 09:53 AM
also, i believe the rcd kit just uses a big spacer like the procomp kit does[/QUOTE]
Does It?
03-06-2008, 10:22 AM
Just get the Fabtech with the coilovers. I have that setup on my 2wd.
03-06-2008, 12:19 PM
[QUOTE=Davespeed]Just get the Fabtech with the coilovers. I have that setup on my 2wd.
Do you have the coilovers? How are your angles? Do you think I could fit those tires and wheels without rubbing?
03-06-2008, 01:07 PM
I don't believe RCD makes a lift for 04-08 4x2's.
2005 Expy, 305/45-22 Falkens on 22x9.5 Eagle 026s.
2011 Jeep Wrangler Unlimited, 2" lift, 33" BFG AT KO's on 17x9 Eagle 197s.
2012 Ram 2500 crewcab diesel. 5" RCX lift, 355/60-20 Nitto Terra Grapplers on 20x9 KMC XD Spys.
03-06-2008, 01:11 PM
03-06-2008, 01:26 PM
Quote:
Sorry I meant cst
03-07-2008, 04:16 AM
will it fit?
03-07-2008, 10:38 PM
Ok I changed my mind i would got the mazzi hulks bs4 1/2 and offset -25 with the toyo mt 35X12.50 would it fit.
03-08-2008, 10:29 AM
They should.
03-08-2008, 11:07 AM
Quote:
I have 20x8.5 with a BS of 5". You might rub a little with BS 4.5" on a 10" wide rim.
03-10-2008, 10:07 AM
Quote:
Do you have the coilovers? What did you do with the rear 5' block or all?
03-10-2008, 11:54 AM
Coilovers, 5" block and going to add 1.5" AAL for towing and level out the truck.
03-11-2008, 01:01 AM
Have any more pics like of your angles or next to a stock 2wd. anything cool would be awesome.
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is On
