Go Back   F150online Forums > Powertrain & Mechanical > Suspension
Sign in using an external account
Register Forgot Password?
Register Photos Vin Decoder FAQ Members Search Today's Posts Mark Forums Read VendorsGarage
Suspension SPONSORED BY:
Thread Tools Search this Thread Display Modes
Old 02-18-2008, 03:04 AM
Garage is empty, add now
Vehicle: 1998 Ford f150 5.4
Question Torsion Bars again! Sry
Ok tommorrow morning Im going to crank my torsions then go get it aligned, I looked under my truck and one is cranked 3/4 of the way and the other is up about a 1/4 (meaning bolts) ,I was told that this is common that they are not equally adjusted but what I need to know is can I turn the one thats 3/4till it bottoms out then adjust the other to even out ? It looks like I make onlly get as little as two turns on the one ,prob could get 6 on the other.Will this make any difference? thanks C
Old 02-18-2008, 03:59 AM
Vehicle: 2004 Ford F150 4x4
Send a message via AIM to mSaLL150
Keep them stock. You want suspension travel, maxing them out decreases your travel, hurts your suspension offroad. If you want lift from your truck, do a proper suspension lift with a correct front differential drop (a.k.a. rancho, RCD, or Fabtech). Otherwise, you risk hurting your suspension, and costly repairs. Do it right if you're going to invest.
2004 Lariat 4x4:
Old 02-18-2008, 09:37 AM
Vehicle: 1997 Ford F-150
I won't disagree that a proper suspension lift is the way to go, but like many others I turned my torsion bars all the way and yes it is a stiffer ride but I'm driving a 4x4 truck w/ mud tire so I expect what I've got. If you crank them get it aligned and keep a check on front end components for wear and tear. Also to answer your question, measure the height on each side before you start, then crank the bolt that's already in more (3/4 way) all the way counting the # of turns and then turn the other bolt the same # of turns, lower the truck and measure again. Keep turning the bolt that's not all the way until you get level. Hope this helps.
Old 02-18-2008, 09:57 AM
Vehicle: 2001 ford f150
I agree with FordTruckin.
2005 Expy, 305/45-22 Falkens on 22x9.5 Eagle 026s.
2011 Jeep Wrangler Unlimited, 2" lift, 33" BFG AT KO's on 17x9 Eagle 197s.
2012 Ram 2500 crewcab diesel. 5" RCX lift, 355/60-20 Nitto Terra Grapplers on 20x9 KMC XD Spys.
Old 02-18-2008, 11:03 AM
Smile
thanks for the info ,I do have a 4" Ranco lift already. Just tryin to squeeze another 1.5 inches if I could.Just have to go find some level ground! Thanks again!
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company
Emails & Contact Details
Search Engine Friendly URLs by vBSEO 3.5.2
