02-13-2008, 05:42 PM
2" shackle drop wedges?
Yea i just got my ground force shackle drop in and it didn't have the pinion correction wedges, Does anyone know what degree they are. (3 or 4 degree).
Reason why there is a place right down the road that has them i just need to know what degree. Tks
02-13-2008, 05:47 PM
Global Moderator & Senior Member
2005 Ford F-150
Vehicle: 2011 Ford F150, 5.0
You might try the Ground Force web site.
02-13-2008, 05:49 PM
2005 Ford F-150
Vehicle: Fort Lauderdale
I was told that 1* for every inch of drop
02-13-2008, 07:55 PM
Tks.
Yea i tried their web site it is down lol , called them , an that is why i turned to this forum
02-13-2008, 08:36 PM
You get some vibration or other problem on newer trucks if you don't shim?
(Put the shackles on my '98 without shimming.)
02-14-2008, 03:59 PM
Well talked to ground force today, its a 2 1/2 * wedge, incase anyone wants too know.
2011 F-150 XLT ecoboost
with 08 fx2 20" wheels
5STAR Custom tune
MagnaFlow cat-back
Afe Stage 2 intake
02-14-2008, 04:04 PM
2005 Ford F-150
When I bought my 2" kit and had it installed. I told them the reason I wanted the Ground Force was because it came with the wedges. They brought my truck around after installation and the wedges were still in the box. The installer said it didn't need them as I had the two piece driveshaft. I told him, i wanted them installed as the pumkin would be out of alignment even if it didn't vibrate. They went back and installed them.
02-15-2008, 11:51 AM
Garage is empty, add now
Vehicle: two 2003 F-150s
blue you shoulda had me do them for you
yes its roughly 1* for every 1" drop, but not always. Only way to see exactly what you need is put your drop on and check the driveshaft angle with the appropriate gauge.
It is the pinion angle you are worried about.
02-15-2008, 04:46 PM
You would have no problems without them unless you were loaded but 2 degrees will be plenty and make sure you put the fat side of the wedge on the front when lowering.
02-15-2008, 05:25 PM
you sure the directions say's to put the "fat side" to the rear. ?
02-15-2008, 05:41 PM
Fat to the rear is for lifting because when you tighten the u bolts down the axle will suck to the gap which will turn the axle upwards towards the transfer case. Since your truck is lower the driveshaft angle needs to come down.
02-15-2008, 05:44 PM
2005 Ford F-150
Yep, it seems backwards but isn't.
02-16-2008, 04:51 PM
02-16-2008, 05:21 PM
If you put the shim in with fat to the back it will be the same as putting on a 4" drop with no wedge. Go to beltech's website and under the tech support - install sheet - kit 6419 - step 18 which is for the 97-03 it will say the fat to the front. If you want to put it fat to the back then go for it but you'd be better off just not putting the shim in at all. Just think about it for a second and it makes sense. The axle has to move wherever the gap is because the leaf springs definitely won't be the ones to move. If the gap is towards the front then the driveshaft will suck upwards which is good for lifted trucks and bad for lowered ones. If the gap is to the back the driveshaft will go downwards which is what you're looking for.
02-16-2008, 06:58 PM
2005 Ford F-150
Vehicle: 2005 Ford F150, 2008 Ford Taurus X
When drop shackles are installed the spring pack pivots up towards the truck bed, therefore making the pinion angle pivot up towards the truck bed as well, which makes the pinion angle wrong. Adding the shim with the fat part towards the rear corrects that wrong pinion angle back to stock.
Lifechurch.tv
Quote:
Originally Posted by ian51279
Those of you who think you know it all are very annoying to those of us who do.
Quote:
Originally Posted by Albert Einstein
The difference between genius and stupidity is that genius has its limits.
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is On
