Help! 2005 F150 Fx4
35's on stock rims is what alot of guys are using. You will have a problem when you start using aftermarket wheels due to the backspacing. the 35's are not recommended for the 7.5" wide wheel due to the tire width. About the only problems you might have is slight rubbing on full turns and abnormal wear in the center of the tire. I have had 33's on my factory wheels with a 2.5" leveling kit for 30,000 miles. 35's look nice, but I am working my way up now that I have a 4" lift. Once these 33's wear out, i'll get 35's.
I just had the bfgoodrich km2 put on saturday.So far no rubbing at all. They are a great tire and not real loud running down the hiway.Check my gallery for pics.
https://www.f150online.com/galleries....cfm?gnum=8306
