Torsion Bars...
Old 12-05-2007, 01:57 PM
Gingo01SCrew4x4's Avatar
Torsion Bars...
I have an 01 Screw 4x4 and have read the threads on leveling by cranking the torsion bars. I have a couple questions...
1. Do you cause any problems when doing this? is it possible to over torque them? Has any one had them break once you go off road?
2. When cranking them where is a good measurement point on the body, frame, etc to ensure both sides have been adjusted the same?
Old 12-05-2007, 01:59 PM
1. stiffer ride, yes you can over crank them
2. count your turns as you crank them you will need to realign the truck too
Old 12-05-2007, 02:02 PM
mark03screw's Avatar
How much does a realignment usually cost?
Old 12-05-2007, 02:03 PM
depending on where you take it anywhere from 50-100
Old 12-05-2007, 02:10 PM
attworth's Avatar
NTB - 75$ for one..
- 140$ for unlimited for 3 years... Definitely a good deal.
Quick Reply: Torsion Bars...
