Technically...What size?
Ok, I'm getting Closer to My Body Lift and 38's. I know this is kinda silly, But I know I'm not the only one that has wondered this. If I am Running a 6" Fabtech, a PA 3" BL, T bars Cranked (adding another... ~1.5") and a 3" AAL, Should I still "Say" I have a 9" lift? Cause "TECHNICALLY" its an 11" But I dont really see people running around saying that
I've never really considered a T-bar crank (97-03s) or a 2"+ leveling spacer (04+s) as a lift per say. Or adding AALs just to get it level.
IMO, a "lift", whether it be a suspension or body lift, must lift the entire vehicle to be classified as a lift, not just the front of the vehicle to make it level. Or an extra AAL in back.
I'm sure some people will argue this point, but it just bothers me when people say I have a 2" lift in front, when all they did was level their truck. I think being conservative and stating that you have a 9" lift is probably sufficient. Your truck looks bad *** anyway, so I doubt anyone will question you.
Good luck with the BL, are you doing the install yourself?
Originally Posted by Skrewd
Most Likely, I cant justify Paying someone $700 to install it, With a day or two in the driveway and a few buddies, Im sure it can be done
Good luck, I'm sure it is going to look sweet when she's all done.
Originally Posted by ThumperMX113
I consider ANYTHING that gives you lift, the amount of lift you have. So you'd have 11" of lift.
If it was mine, I would say I've got a 6" suspension lift with cranked torsion bars, and a 3" body lift. Is it really that difficult?
Sorry, I don't mean to add to the fire but...
HP numbers and lift are two different things. Anything that "lifts" the vehicle higher than it is, should be considered "lift." Whether you have some nasty coil-over set up on the rear of your truck, or you added a leaf, you're still getting lift out of it right? Now, you wanna talk "Travel," that's another story.
