tires rubbing
It's a combination of the width (10 inches) of the wheels and the backspacing. With a 10 inch wide wheel, I'd want at least 6 inches of backspacing. I bet you have a wheel with a lot less backspacing than that. THe most common wheel specs seem to be a 9 inch wheel with 5 inches of backspacing.
10" wide rim is your problem. The Pro Comp website says that is allows up to 5" of backspacing. Your current rims are probably less, causing the tires stick out past the fender. If you increase the backsapcing on your current rims you'll probably start rubbing on suspension components. Your best bet would be to get a 9" wide wheel.
I'm no expert but this is my guess.
