Rancho 4"
Originally Posted by Tuchy3
Good News!!
Just a few questions for you:
Whats the ride like and which shocks did you use?
Is the wider track width in the front that big of a difference?
Where you get it and price??
Thanks a lot
Thanks a lot
Tuchy I have the same problem as you, I want the 4" Rancho + the XD series. But i cant decide if i want chrome or Black. Copenhagen What size of tires would u reccomend with the 4 inch lift. I was looking at the Toyo Open country M/Ts and the Procomp X tereains. Iam leaning towards the Pro Comp because iam not to sure how the toyo's will handle on all the highway driving i have to do.
I have the Rancho lift and have no problems. I have the adjustable shocks and prefer to make adjustments if needed. The wheels you use will determine how far they will stick out. The kit was tested on an 18x9 wheel with 6" of backspace, so anything different than that I believe will stick out more noticeably. I like the one-piece cradle design type. Less moving parts. Whether they are better or not is a different story, but at least in my mind is a better design. It is actually one of the most recommended lifts on the forum. Along with Fabtech and RCD.
Good Reviews!!
I plan on going with the Rancho now, and with the KMC Rockstars in black with the 35" Toyo MT's
the specs for the wheel are KMC XD 775 Rockstar Black Size: 20x8.5 Bolt Pattern: 6x135 Offset: 35MM Back Spacing: 6.13 inch
Any reviews for this set up would be greatly appreciated. Thanks!!
Thanks copenhagen, appreciate it. Have any of you guys looked into the Roush COLD AIR INTAKE system yet, i was thinking of getting one, but i havent herd anything about it yet might jst stick with K&N. Also when you put on your 35s did you lose any power. If so did you have to reset ur gearing.
Good Reviews!!
Here are the specs on the Rancho kit:
http://www.gorancho.com/html/product..._f150_4wd.html
Wait but how are some trucks with just a leveling kit able to fit them, maybe ill run an 18in
i got to look for the other specs
Get a Fabtech 6" lift, and go with the 20" rockstars with 4.5" backspacing. They will stick out, but you wont need to worry about rubbing because you have a 6" lift, not 4". The fabtech basic kit replaces all of your shocks, and rides great, and costs less then the rancho. So, why not??
Originally Posted by mSaLL150
you seem prett set on running these rockstars. Do this:
