Superlift 4.5" Lift Questions
Hey everyone, I am planning on putting the Superlift 4.5" lift on my truck this winter, ones thing is that under the specs for the kit it says:
For 35x12.50 tire:
• 17x8” wheel with 5” backspacing preferred (5.25” maximum)
• 18x8” wheel with 5.75” backspacing
• 20x8.5” wheel with 5.75” backspacing
So if I wanted to get a set of KMC XD Rockstars it says 4.5" of back spacing am I good to have that set up with 35"x12.50" TOYO MT's?
Any input is greatly appreciated.
For 35x12.50 tire:
Originally Posted by mSaLL150
4.5" backspacing is a little slim, especially if those rockstars are 9-10" wide. Try to keep it close to the recommended specs of the lift manufacturer.
Take a look at my gallery if you want to see what 5.75" backspacing on a 8.5" wide wheel looks like.
Member 05BlackF150 has the Superlift, he'd be a good one to ask about it. Here's a link to his gallery:
https://www.f150online.com/galleries....cfm?gnum=7975
So if thats what it says at ORU.com, KMC XD 775 Rockstar Black Size: 20x8.5 Bolt Pattern: 6x5.5 Offset: 10MM Back Spacing: 5.14 inch
I should be alright with the 4.5" lift and 35" Toyos
Hey also Nooq, what kind of exhaust is that, all specs gratly appreciated, thanks
KMC XD 775 Rockstar Black Size: 20x8.5 Bolt Pattern: 6x135 Offset: 35MM Back Spacing: 6.13 inch has too much backspace. For some reason the 6x135mm bolt patterns don't have the backspace you need. 5.75 backspace is the max according to Superlift. You may have to look for a different wheel.
