Need Advice!
Old 11-15-2007, 08:24 PM
TJ44's Avatar
Need Advice!
I have a 2006 F150 Fx4 supercab, and I want to lift it. I was thinking of getting a 4" Rancho suspension lift or a Pro Comp 6". If I got the 4" what size of tires could you suggest, I was thinking 33" with a 20" rim. If any of you guys have pictures of your trucks I would love to see them. Also what benifits will i have if i cut out the cats of my magna flow exhaust. Will it make it louder, more powerful or what? Thanks for your help
Old 11-15-2007, 08:30 PM
Russ47's Avatar
with the 4" rancho you can run 35x12.50 just like sal fx4 and copenhagen848's fx4 and there trucks look good
Old 11-15-2007, 08:50 PM
wandell's Avatar
I'd go with 35's with both lifts.
If you cut the cats off your truck will be louder and you will loose some low end torque.
Old 11-18-2007, 02:27 PM
TJ44's Avatar
Thanks guys appreciate it. One other Question Thinking about black or chrome Rock star rims. what do you think?
Old 11-18-2007, 02:37 PM
t-rev's Avatar
what color is your truck and what color is the trim?
Old 11-19-2007, 03:54 PM
TJ44's Avatar
Its all black, except for the little bit of trim around the wheel wells. Its dark grey. The same truck as Tuchy3.
Old 11-19-2007, 08:11 PM
wandell's Avatar
Both will look great.
Old 11-19-2007, 10:18 PM
Russ47's Avatar
do the black it will look AMAZING
Old 11-20-2007, 01:52 PM
TJ44's Avatar
If I run 35's on a 4'' lift will i have rubbing issues?
Old 11-20-2007, 01:55 PM
TX-FX-4's Avatar
You might if you don't have the right wheel/tire combo.
Quick Reply: Need Advice!
