How can I tell if I need new ball joints?
Ball joints
Jack the truck up under the lower control arm. Wedge a big screw driver under the knucle/spindle (careful around the dust boot). Try to pry the spindle up relative to the control arm. I believe up to 1/16" of play is acceptable, but take the time to check a manual for specifications. I'd probably change them if I could see anything more than the slightest of movement.
Tie rods, idler arm, and drag link
Leave the truck on the ground not running but key on. Have somebody sit in the driver's seat and rock the wheel left and right just to the edges of the slop in the steering while you lay under the front of the truck. The helper wont actually move the tires. You may notice a slight movement of the wheels and a slight flexing on the tire sidewall. If you see any relative movement in any of these parts, change them.
Ford did send a notice on how to inspect these parts. Water was an issue for the stock parts. I believe they wanted you to peel the boot off the shaft slightly and look for water or rust and change the part if you see any of either or any movement. I don't know where to find Ford's inspection recommendations, but they will help you do this to Ford's procedure.
