Bilstein 5100 install...
Until I can get this lift put on.. I'm going ahead and installing the Bilstein 5100 adjustable shocks I just ordered to go on with the lift. How difficult is it to install? Will the shocks come with instructions? I'm assuming pull the spring... It won't require a alignment will it?
Thanks.
Thanks.
So basically what I need to have done is pull the shock and replace it? I'm not sure why you're saying take it in and get it done... It seems pretty simple. Am I missing something?
Can't I just rent a spring compressor and do it in my driveway pretty easily? Thanks for the help... I can take it in if I must, but I'd rather do it myself...
I guess I could just wait till I get the lift put on. Alignment included.
I guess I could just wait till I get the lift put on... Alignment included....
Originally Posted by bud8817
NICE. i just didnt want a coil coming lose and ripping my face off!!! haha and at that point i didnt even know you could rent one.
Originally Posted by Maxout05
07fx4silver. Did you take out the autospring leveling kit when you put the bilsteins in?? If so is the ride different between the too leveling kits??
I guess it would be OK to run the Bilstein and at the same time, leave some type of leveling kit in place AS LONG AS you do not adjust the shock any. Is this correct???
If you don't leave the new shocks adjustment feature in the stock (no lift) setting, now you're getting into extreme angles. Am I looking at this right??
