Need A Lift For Fx4
Need A Lift For Fx4
I have a 05 FX4 SCAB. I leveled the truck 2" in front and put 305X65X18 BFG AT KO's on. There is no problem with rubbing until I turn on uneven surfaces. I want to raise the truck up so I can offroad and go over uneven surfaces without rubbing. What lift do I need just to accomplish this? I don't want to spend a lot. I was thinking of the 6" basic fabtech lift. What are your thought. Thanks in advance.
how much does the PA 3" cost?
where can I find a body lift for a good price?
no wonder, you have 10" wide rims with a 33.5" tire.
do yourself a favor, get a suspension lift. It sounds like you want to do some offroading. Maybe consider the 4" rancho. It will fit your tire/wheel combo perfectly, and comes with a great set of shocks which will be perfect for you if you want to have some fun. It will also put your CVs back to normal.
