want to add coil springs if possible?
Old 11-06-2007, 11:17 AM
firemedic30129's Avatar
Question want to add coil springs if possible?
i have been trying to increase the lifting load of the front end of my 2001 f150 4x4 and it was suggested that i try to add springs to the front end. if this is possible can anybody tell me how to do it?????? i mostly need the extra lift in the winter time for the snow plow. i do have the torsion bar suspension and i maxed them out then backed them off one turn.
Old 11-06-2007, 05:00 PM
jdrozdow's Avatar
What is your truck rated at?
I am assuming that you have a 2004+ MY truck (P221). With that said, there was a 7700lb HD package. Is that the one you have? If not, you could buy a set of 7700 lb front shock/spring modules. They will fit your truck as is. If you need more you will have to go aftermarket, but beware. The current springs are a tight package to begin with. Watch your clearance to the tires at rebound in turns.
Old 11-06-2007, 05:41 PM
bud8817's Avatar
(jdrozdow)it says he is a 2001 friend...
your truck is a 2001 correct? if you have coils you are a 2wd? other wise you would have torsion bars (if you were 4x4), and we would be taking about something completly different.
buy a daystar 2.5 leveling kit not sure about price but that should work great. you can also fit some bigger tires with that aswell.
Old 11-06-2007, 05:58 PM
keith_bennett's Avatar
I agree.
Old 11-06-2007, 06:21 PM
jackedup4x2's Avatar
daystar
i just installed my 2.5 daystar on my 99 2wd...it ran me about 100$...installed it myself...then the alignment was 66$
Old 11-06-2007, 10:38 PM
jdrozdow's Avatar
Missed the 2001 note in description.
All agree that 2001 4x2 has coil springs and 4x4 has torsion. How does a snow plow work on a 4x2? I have had 4x2's and even with LS rear axle I can't emagine pushing snow.
Old 04-09-2008, 11:45 PM
lgamez's Avatar
Bud8817, were can I find this ?
Can I buy it online ???????
Old 04-10-2008, 12:24 PM
Galaxy's Avatar
Man!! I guess all you guys need to take an english class He said in the very first scentence it's a 2001 4WD!!
OK, with that out of the way...
firemedic, you basically have two (realistic) options. Max out the pre-load adjustment on your bars...which you've already done. (but there's no real need to back them out one turn, leave them full in)
Your other option is to locate a '99-'00 F-250 LD. (It's a F-250 that's the exact same body style as your F-150) It has the 7,700 lb payload package which included heavier torsion bars. They should be a direct one for one swap and will add some extra support. Adjust them as needed.
I've shopped...no one makes an aftermarket cool torsion bar for our trucks that I can find. There's also no coil spring and/or coil over conversions for our trucks...outside some very high dollar custom jobs.
Quick Reply: want to add coil springs if possible?
