Installing bilsteins
Originally Posted by ThumperMX113
It's easy man, don't be scared about it. The only part you'll have to do which might be slightly hard is getting a set of good spring compressors and compressing the spring.
The spring compressor is two pieces, which have hooks on both ends which go on the coils of the springs at each end. They also have bolts on each ends which you tighten and it'll squeeze it together. I know some places will do it for you for $10 but it's really easy. A lot of auto stores will loan you the tool if you don't have it.
Originally Posted by wandell
I'd suggest removing the OEM shocks and taking them to a shop that has a heavy duty spring compressor. Just pay them to remove the coilsprings from the OEM shocks and install them on the new ones. Most shops that do strut replacements will have a heavy duty spring compressor.
